Lift Pump Puzzle....
Switched to P4601HP, moved it to frame rail near tank. Used big banjo on filter inlet. Should have seen 18 psi, no? Fired it up and got 10 psi. 10 psi idle and 9 psi WOT. I am puzzled?! Used to see 15 idle and 9 WOT. ??????
Double checked with another gauge, same result. Looks like I'm getting a well regulated but low pressure flow.
Label on pump sez it should be used with Part #XXXXXXX regulator....
I can see a regulator to lower pressure if it's too high. But ***? Parts store has another pump coming tomorrow. Guess I'll try that and see what's up.
Any ideas?
GrampZ
Any ideas?
GrampZ
i put the bully dog big fuel kit on my truck and used to see 24 lbs of pressure at idle and about 20 at wot. then it just dropped to 10 psi at idle. my stock lift pump crapped out and i just bypassed it. now all i carry is 12 psi at idle and 9-10 psi at wot.
Any ideas?
GrampZ
Any ideas?
GrampZ
In the event of low voltage, a relay with the ECM/pump wiring providing the signal and a straight wire w/fuse from the battery going to the "work" connections of the relay.
Don't bother with 4601hp they don't last went through 4 pumps in a year doing the same as you did. Just use org. replacment should get a year or so out of it My last pump lasted 11 months 2 weeks still got a new one on warrenty. Any cost out of pocket now will go towards fass pump
Any ideas?
GrampZ
Any ideas?
GrampZ
nitrousn, 9 psi at wot isnt "really good" It's more like "ok, but-could-be-better" its border line to low
anyways, im running a holley blue, pushing somewhere in the neighbor hood of 26-28 at idle and never under 15 at WOT. And their cheap and easy to install
Originally Posted by Clunk
You might check the voltage to the pump. .
Blackdiesel having all that fuel pressure is fine. Her is my take most factory lift pumps will pass the volume test at 4 to 5 psi wot. All the extra pressure does nothing for performance or longivity of the vp44. I see so many people on the quest for unneeded fuel pressure and waste tons of money and toss perfectly good pumps in the trash trying to do so. Ask j-body and he will confirm what i am saying. If i need a new pump i would go with the walboro and the big line kit. To me thats the best bang for the buck. I have a vulcan big line kit and a cummins recall pump on the shelf waiting for my oem pump to die. When i drop to 4 psi or less on wot i most likely will go with the walboro kit and sell my other items off. I closing all i will say is verify the volume before you condem a pump.
Carter p74213 is a direct replacement for our trucks, banjo's and all work right out of the box.
Have 2 years on mine now and still idles at 17 and 12 WOT. All the guys I know around here all run them and they have similar results. I'm not saying it the end all but it's the best I have found for OEM type replacement pumps.
The FASS pumps and all similar types are great but when your in the middle of nowhere and need a pump, the Carter isn't the greatrst but it's available most anywhere in a pinch.
Jeff
Jeff
