Lift pump primer timer
Ok, I don't know what it is called, but you know, when you first turn on the key and the lift pump runs for a brief period to prime the injection pump. How long is the lift pump supposed to run? Mine is only running about a half a second, it seems to me that it used to run longer. Is there a relay to replace for this? Any help would be greatly appreciated..
Actually the manual says it should run for about 1/4 of a second. Like mentioned earlier by someone, it can run for about 25 seconds when you bump the starter.
The lift pump is self priming...I didn't see anything that mentioned a primer timer.
Mine has always run for about 4-5 seconds at key-on but lately it may alternately run for 1 second if that, so I am interested in learning from this topic also. Still runs for 20 seconds or so at bump but I shouldn't have to prime IP that way. But I don't have an in-tank lift pump so that might make a difference.
The ECM controls how and when the pump will run. Two modes of operation with eng running, 1, 100% duty cycle with min 10psi except when cranking then 2, 25% duty cyc with 7psi min when cranking. When key first turned on will run for up to 2 sec, pump will run up to 25 sec when starter engaged then disengaged with eng NOT running. (starter bump)
The 25% cycle is used to limit injection pump inlet press until eng running.
