lift pump going??
Old Nov 2, 2009 | 06:29 PM
kennyhammond's Avatar
lift pump going??
i have a 2002 dodge i have a edge comp box set on 40 when i go and hit around 1800 rpm it surges (cutsout) but if i turn my chip off the truck does ii higher rp like 2200 this happened before and the lift pump was going bad is there a way i can check it my self since the only person around my town said it would cost me 100 for him to tell me i just replaced it like a year ago it shouldnt be bad yet should it?
Old Nov 2, 2009 | 06:58 PM
Silver R/T's Avatar
turn key to on and off 3 times, if there's any codes they will be displayed on your clock in P0000 format. You should get fuel pressure gauge to see what PSI your pump is getting.
Old Nov 2, 2009 | 07:00 PM
PChouinard's Avatar
you have to get a fuel pressure reading if you don't then you can never tell if it bad or not the fuel pressure is very critical if it is bad the lp has to pull it's own fuel so it won't be there when a demand is placed on the injectiuon pump you should look into punctuation also JMHO
Old Nov 2, 2009 | 07:10 PM
Were do I get one at? And are they spendy?
Old Nov 2, 2009 | 08:40 PM
drp23's Avatar
Is 6 lbs @ Idle good stock or going (south), thats what mine was when I put my AD on.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
cummins24
Aug 14, 2004 08:01 PM
gofastman
Aug 14, 2003 04:24 PM
silverram323
Jul 7, 2003 02:52 AM
