Lift Pump Bad?
Old Nov 30, 2005 | 03:27 PM
shellman's Avatar
Question Lift Pump Bad?
Codes were P0460 and P 1693 thought fuel sender was bad added 10 gallons diesel, changed fuel filter, when bumping to get diesel to fill filter bowl no fuel comming in, but lift pump is making noise. Thanks for your suggestions.
Old Nov 30, 2005 | 03:36 PM
John Faughn's Avatar
Either the lift pump is bad or there may be a leaking fuel line , the LP motor can be running and the pump part not work , try using a small container with an hose to LP to see it works .
Old Nov 30, 2005 | 04:05 PM
shellman's Avatar
John lift pump has 181,000 miles from factory, I don't see any leaks in line, so it will still make a noise but no output correct? Thanks
Old Nov 30, 2005 | 04:48 PM
Geico266's Avatar
I'll guarantee the LP is bad!
This is why you need a fuel pressure guage.
Old Nov 30, 2005 | 05:04 PM
shellman's Avatar
Geico,
I am reading post and getting more frustrated. People say that even if it is bad lift pump that VP-44 should pull fuel, this truck just turns over. If I fill filter bowl and tighten will vp-44 pull it to injectors then I know it is the LP, and lastly there are no pumps in tank on 2000 correct. Thanks for the help, Big Red will Run soon Again .
Old Nov 30, 2005 | 05:41 PM
Geico266's Avatar
Geico,
There would be too much air in the system for the IP to get it all out. IMHO. Do it right. Replace the LP before you do anything, or you will ruin the IP to the tune of $1,600 if you haven't done so already.
Old Nov 30, 2005 | 05:56 PM
Ph4tty's Avatar
The lift pump is mounted on the engine, below the FF on a 2000. I got mine at Napa, although a cummins dealer could order it for a few dollars less.
It might be a clogged fuel line, but with that many miles on that LP it'll be due for replacement anyways- and while you're at it you might want to upgrade your fuel lines and banjo bolts. DTR has a kit in their online store
Old Nov 30, 2005 | 08:33 PM
phox_mulder's Avatar
The VP44 can pull enough fuel to keep the truck running, this is if, and only if, the system is primed.
Once you break prime by running out of fuel, changing the fuel filter, or draining the water from the seperator, it can't pull the fuel.
Also, it can only pull enough fuel for the engine, it can't pull the extra fuel it needs for lubing and cooling itself, the lift pump is the one that supplies this extra fuel.
Your lift pump is bad if it can't fill the bowl, a good lift pump can fill the bowl in 10 seconds or less.
phox
Old Dec 1, 2005 | 10:12 AM
Mopar1973man's Avatar
Something else that everyone is forgetting to tell him to buy!
You NEED to buy a fuel pressure guage.
Then you will know if the LP pump is dieing next time. But I would say you LP is dead. I would replace it now before you do ruin a $1,300 - 1,700 IP VP44 pump. LP is cheap to replace...
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
loveturbowine
Jul 26, 2005 05:50 PM
Txwelder
May 19, 2005 06:10 PM
C Pierce
Mar 21, 2005 08:41 AM
