Killed 3 new vp44's in a week
Old Aug 29, 2008 | 10:01 AM
wildchild97's Avatar
I have a 02 with a redline, ez, 150 inj, and a turbonetics turbo... I recently had the motor redone and since i put it back together I have killed 3 vp's in about a week I had them rebuilt by diesel injection in louisville, its there hot rod pump that keeps going out.... It has burned the first two up within a few mins and the last one lasted about 3 days of normal driving.... I have a Holley Black with 1/2 pick up tube in tank and 1/2 lines all the way to the inj pump... I am holding 15 psi ideling and 12-13 a WOT with the redline... I have had the redline both on and off the truck and it was just recently sent off and redone.... Any help would greatly be appreciated this is getting really expenseive.... Also i have had my injectors pop tested by diesel injection, they seemed to be fine.... The pumps seem to be burning up the psg, i checked the voltage at the hot wire on the pump and it was at 12.38 volts.... I have also looked over the wiring harness and seem to see nothing wrong there either
Old Aug 29, 2008 | 10:35 AM
SINGLESTACK's Avatar
It sounds like that motor wants a p-pump! Did you check over all the wiring for the redline to make sure nothing is shorting out?
Old Aug 29, 2008 | 12:36 PM
mopar-or-no-car's Avatar
Is ther no warranty on the pump at all? I had my replacement pump die after about a month and BD replaced it for free. You would think even if you tapped the wire and it only lasts a couple hours you would still get some kinda warranty
Old Aug 29, 2008 | 02:19 PM
scottsjeeprolet's Avatar
Double check you Redline wiring. T.J burned up his Hotrod 44 by hooking it up wrong.
Old Aug 29, 2008 | 11:05 PM
camododge's Avatar
It's gotta be a wiring issue. There's no reason to be burning through them like that. I'd also think that after just a few minutes of running and they are dying that the shop would warranty them even with a tapped wire.
Old Aug 30, 2008 | 02:53 AM
Tate's Avatar
Check your wiring, like was said. If that checks out, shop elsewhere for a VP. Maybe they are not up to par?
Old Aug 31, 2008 | 12:04 AM
Kman9090's Avatar
What codes are u throwing? By chance is it p0254 or p0253?
Old Sep 1, 2008 | 05:03 PM
Sometimes it throws a p0253 but only sometimes,
Old Sep 2, 2008 | 08:34 PM
Kman9090's Avatar
i would say its something to do with the redline! The 3 days that it lasted how was it runnin?
Old Sep 2, 2008 | 11:06 PM
dodge_diesel's Avatar
its time to p-pump
RyeThomas
Jul 11, 2007 04:31 PM
ShaneCTD600
14
Apr 15, 2007 11:42 PM
Tiny
Jul 16, 2005 11:14 PM
CUMMINSBILL
Jun 6, 2003 10:02 AM
