just found out i got a "53' block- how bad is it??
Old Dec 10, 2005 | 10:36 PM
  #31
singleturnout's Avatar
my 53 cracked at 120,000mi with no towing
Old Dec 10, 2005 | 11:49 PM
  #32
torquefan's Avatar
Originally Posted by J BODY
Just worked on an 00 with a troublesome electrical prob. I crawled under it to check the harness and there was the big 53 on the side. I went and looked under the pass side and there were stains from leakage and a 6-7 inch long crack in it. This is the FIRST 53 I had seen with a crack at work. It was probably in 2002-2003 that I first heard of this, and it was HERE that I first read info on it.
Similar experience here too. I work on these trucks every day, and after finding out about 53 blocks here, I started keeping an eye out for them. Turns out I see lots of them, and most are worked pretty hard. One's a tow truck, now with over 300 000 miles on it, still ok. After all these years, I've only seen one with a crack.
Old Dec 12, 2005 | 09:42 PM
  #33
MFEUSAF's Avatar
i have 256K on my 53 block, and have about a 12-14 inch crack on it too.. pulled it once and welded it.. put it back in. ran it for about a month. started leaking again. so im just goina replace it insted of grinding it down and re welding it. im kind of babying it right now. it will spill out about 2 gallons of water in about a hour of driving.. no fun toppin off the water at every stop.
Old Dec 20, 2005 | 01:42 AM
  #34
KATOOM's Avatar
Thats a big crack. I was wondering though, how difficult was it to remove the engine from the truck. I know how it is. Once you do something like that there is always a couple of bolts and washers left over and nothing ever looks and feels the same.
Old Dec 20, 2005 | 02:25 AM
  #35
FozSweet53's Avatar
I hope its blown out of proportion, cuz I found the big 53 about two weeks after buying my truck. 106k and no cracks, most mods have been in place for approx 50k. I'm good friends with the previous owner and he towed a big 5th wheel and an enclosed car hauler quite a bit. I for one am not going to sit here and cry in my beer, if she cracks I'll find a new block.
Foz
Old Dec 20, 2005 | 09:01 AM
  #36
MFEUSAF's Avatar
the engine wasent hard to pull at all really. just take the bolts off the tranny and mount bolts. you prity much have to take the whole frount end out radiator, intercooler.. but other than that. the hardest part was taking off the wiring harness that wraps around the engine. but got it nickelrod braised. no luck. i recoment muggyweld for anyone that decides to weld it.
Old Dec 20, 2005 | 10:23 AM
  #37
Mcmopar's Avatar
That is a pain, you cannot view posts over 10 days old!! I would be interested in what he said??
Old Jan 9, 2006 | 05:27 AM
  #38
Katmandu's Avatar
Talking
Originally Posted by xmr
I can't understand how Cummins and Dodge managed to get by with out a recall. The #53 block was designed for a 90 hp engine and Some manager at Cummins decided it was a way to maximise the profit margin on our engines.
Bayliff !! Wack his peepee!!
Old Jan 9, 2006 | 05:42 AM
  #39
Katmandu's Avatar
Thumbs up
Originally Posted by JaredOlsen
I looked at the case where the 53 should be and there is no numbers however right above where it would be there is some numbers and letters that don't apear to be as large as the pictures of the 53 I have seen.
Just where exactly does one needed to be looking for these #s ??
And where exactly are the cracks showing up ?? Pics please!
BTW, here's the pics of the 53 blocks from the other website.....
#1) Showing the Casting flaw....
#2) Good Block....
Old Jan 9, 2006 | 06:04 AM
  #40
Katmandu's Avatar
Exclamation
The BIG 53 is "normally" found below the Injection Pump on the block right above the oil pan. It has ALSO been found elsewhere on the block! So BEWARE!
Here's where they crack.....
Along the bottom edge above the oil pan on the Passenger's side Rear.
Old Jan 9, 2006 | 09:39 PM
  #41
KATOOM's Avatar
Thanks Katmandu, those are the pictures I (probably we) have been waiting to see from TDR. Now I understand what was said earlier about casting flaws. BUT one thing I really dont understand is why I keep reading that the number 53 is not always in the same location on all the 53 blocks. You'll read that its "normally" in this spot but you can find it anywhere on the block. That tells me that the 53 casting was cast in more than one location with more than one cast mold. Which must mean that there has to be different 53 blocks, right or am I way of base? There must to be a better reason why one guys block lasts 50k miles and others last 300k towing.
Old Jan 10, 2006 | 03:15 AM
  #42
Katmandu's Avatar
Arrow
Sounds reasonable to me.
This evidence proves there was MORE than ONE MOLD for the 53 Series block.
Now, if it can be determined..... Where was the location of the #53 on the blocks that cracked. ........I think I'll post a Poll question on this......
BTW, I just found on my 98 CTD has the "dreaded" #53 block. My truck has 191k miles on it. It was used by the PO to pull a big 5th wheel and has been Moderately Bombed.
3500_CTD
13
Jan 29, 2009 09:38 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Alphacowboy
Apr 24, 2006 07:45 AM
dodge2000
Feb 16, 2005 07:36 AM
doomgaze
Feb 6, 2003 06:51 PM
