just found out about the tone ring mod just a few ??
Old Jan 29, 2009 | 06:30 PM
3500_CTD's Avatar
hey guys guess you can say i been outa the loop on this one just read about this the other night and was lookin at alot of the threads started about it sorry to start another but does any one have any pics of the steps in doing this and any tips on doing this seeing how every one probly has this done but me
thanks guys, Dave
Old Jan 29, 2009 | 07:09 PM
Mexstan's Avatar
Did the mod myself, but did not take any pics. A couple of years ago there was a long thread on this and seems to me that someone posted pictures of the steps. Pics are not really necessary as it is so simple.
Old Jan 29, 2009 | 07:13 PM
cameroneod's Avatar
Crack it open and check it out. You'll get it, no problem. Two small screwdrivers are useful when walking it out.
Old Jan 29, 2009 | 07:21 PM
Mexstan's Avatar
Two small screwdrivers????
Seems to me that we are talking about two different tone ring mods.
Some of you newbies may not know that there are two tone ring mods, one is free and the other costs. Both appear to work about the same.
Old Jan 29, 2009 | 07:23 PM
3500_CTD's Avatar
Originally Posted by Mexstan
Did the mod myseld, but did not take any pics. A couple of years ago there was a long thread on this and seems to me that someone posted pictures of the steps. Pics are not really necessary as it is so simple.
yea i think i saw that thread but the pics were no longer avaliable or i couldnt see them on my computer i know it sounds pretty easy to do but i just like to see pictures im sure some of you know how it is.
Old Jan 29, 2009 | 07:40 PM
cumminshakesit's Avatar
just pull off your intake to the turbo. you'll see a tapered ring just inside, held in by a small retainer ring. looks like a snap ring without the wholes... anyway pop out that ring with a screwdriver or scribe... pull out the tapered silencer ring, bam! bam you got a whistlin turbo! careful not to let any FOD (Foreign Object Debris) into that sweet turbo. hit me up if you need any more help.
Old Jan 29, 2009 | 08:02 PM
3500_CTD's Avatar
no i knew about the silencer ring i took that out i was talkin about the mod you do to your pully for the timing to get some more MPG and little more pep in its step
Old Jan 29, 2009 | 08:36 PM
SCCSURF's Avatar
Can someone explain the silencer ring mod? I've never heard of it. What does it do, just make more sound from the turbo or exhaust?
Old Jan 29, 2009 | 08:45 PM
TedT's Avatar
Remove the crank shaft harmonic balancer by removing it's four bolts. Behind the balancer is a toothed ring called the tone ring, it will slide right off. The tone ring has five holes in it, one is for a dowel pin to hold the ring in exact timing to the crank shaft. The other four are for the balancer retaining bolts. These four holes are a little over sized so that if it wasn't for the dowel pin the ring could be rotated a few degrees. So, drill or file the dowel pin hole in the tone ring enough that the ring can be turned clockwise as viewed from the front till the retaining bolts prevent further movement, retorque bolts. Good for a little more low end torque and about 1.5mpg. Oh, the size of the hole is not important as long as it's big enough.
Ted
Old Jan 29, 2009 | 09:06 PM
Spooler's Avatar
You have a Smarty... It gives you enough timing, so you don't need it. I took my Rokktech off when I got the Smarty cause it had timing rattle sometimes. Spend your time on something else, you don't need to do it.
Old Jan 29, 2009 | 09:31 PM
3500_CTD's Avatar
yea there is a big snap ring and you take that out and then the silencer ring will come right out after the snap ring it just makes the turbo whistle louder
Old Jan 29, 2009 | 09:36 PM
SCCSURF's Avatar
So I can take the snap ring and silencer ring out, then put the intake tube back on for more turbo whistle. How much louder is it? Is there any other performance gains from this? Thanks for the knowledge.
Old Jan 29, 2009 | 09:37 PM
3500_CTD's Avatar
yea but cant i put it on just the fueling numbers and some of the guys said they had no problems with both timing it wouldnt hurt to try im guessing if its that easy to do, and put back if any problems, right?
Ted
thanks sounds good gonna try it next time i get a little time and motivation
Old Jan 29, 2009 | 09:38 PM
3500_CTD's Avatar
yea thats all you do absolutely no power gain just the sweet sound of the turbo.
Dodgezilla
129
Nov 18, 2005 11:43 AM
BossHogg
Sep 30, 2005 06:31 PM
Dodgezilla
Sep 30, 2005 12:56 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
