Jumping In and Out of Overdive.
Over the past few weeks under different circumstances my overdrive / torque converter keeps "unlocking". I remember reading in the thread it was electrical. My voltage at idle reads 13.8v which seems low to me. When I check the Red Tops when it is shut off it is 12.5 which seems low also. The lights seem dimmer also.
The Red Tops are about 2 years old. I do leave a DeWalt battery charger plugged in all the time, but it shuts off automatically when the battery is charged.
I read a thread about this problem awhile back but could not find it on the search.
Any ideas?
Any ideas?
Originally Posted by Geico266
Come to find out it was the bruses in the alternator. After replacing them the voltage output is up to 14v. Easy fix for $30.
Originally Posted by Extra300
Where did you get the brushes? The dealerships don't seem to have them.
You may as well order the HD starter contacts and plunger as well...will save you some big $ in the future.
Over the past few weeks under different circumstances my overdrive / torque converter keeps "unlocking". I remember reading in the thread it was electrical...... I read a thread about this problem awhile back but could not find it on the search.
9 times out of 10, IMO, the electrical problem points back to weak/dying batteries on the 47re. Only takes one weak battery to do it.
RJ
When I had this problem I had the trans serviced (time for it anyway) and did a APPS reset, helped but not a complete cure. Battery load test (Snap On tester) showed both yellow tops crapping out, one at 60% and one at 70%, replacing the batterys did the trick and trans is just fine now, kind of surprised me as I didn't think that being down 30-40% would cause that kind of problem, everything else was ok electrical wise
I read a post from Barracuda (THANKS MAN) and tried cleaning the ground on the passenger side battery to the passenger side fender. It is just screwed into the painted fender. I scraped off the paint in that area and cleaned the parts on a wire wheel. It's worked great so far. It's a small black wire just screwed into the fender or the best fix is to run a new ground wire from the PMC to the battery itself. The grounding system DC uses is pretty weak after time. Cost $2.00.
This is after I reset the APPS by the correct voltage. The reset helped 90% and the regrounding ended the jumping all togeather.
Here are the instructions for re-grounding.
OK, I took a look last night at the wiring I had did for the extra ground..First thing you will need to do is remove the factory air box to get access to the PCM and disconnect the batteries as a precaution b/c you are playing around the PCM, you will notice their are (3) seperate connections going into the PCM w/ multiple wires in each one. The one you will need to work with is located furtherst right (3rd one over, closest to the drivers side) , you will find (2) wires which are both ground wires, they are black w/ tan tracers and are located right next to each other . Once located, use a "scotch-lok" type connector to attach to one (or both if you choose) to the wire that will run to the battery (i used a 14 awg wire, i do not think that is critical), they are small wires and you do not have a ton of room so be careful not to rip the wire from the factory plug, i pulled the plug from the PCM to make it easier . Run the wire over to the passenger side battery and make a good connection to the Negative battery post (clean ALL terminals of all batteries at the same time), you are done! I had tried the "re-flash" from the factory to cure this problem and it worked for a week, tried the "APPS Reset", didn't work at all. I will tell you that I first ordered the DTT noise filter (about $30) to cure this problem, I hooked it up and it helped but did not totally cure the problem and about a week after that I ran the extra ground and for around 8 months it has NEVER once acted up, the reason I am telling you this is I can not say for sure if the ground itself TOTALLY cured the problem or if both needed to happen to ultimately cure it. The ground makes a lot of sense if you think of the root problem causing the erratic TC lock and un-lock, if you find you need to do both, contact DTT Transmission and get the noise filter too, it is well worth the $30.....Please let me know if the ground alone cures your problem, I am very interested to know if I even needed the DTT filter...Good luck, let me know if u have any other questions.
CTD2001
May 17, 2008 08:34 PM
