intank lift pump conversion
Old Oct 15, 2009 | 02:01 PM
lander's Avatar
hi i was wondering what are the advantages of having an intank lift pump conversion?
Old Oct 15, 2009 | 02:45 PM
birddoctor's Avatar
From what I've read there are none.Get you a FASS Air dog,etc.You'll be much better off
Old Oct 15, 2009 | 04:12 PM
patdaly's Avatar
Some say there are no disadvantages, I wish they had to freeze their tails off dropping a tank to replace a Lift Pump.
Personally, I would follow birddoctors advice unless you want to do like I do and just buy a replacement pump.........30 Min or less and I have one changed.
Old Oct 15, 2009 | 07:37 PM
BigIron70's Avatar
Cummins Guru
From what I've heard Fass is better. I have installed in tank pumps but see no advantage, filter screen is much smaller with in tank pump and more prone to plugging up over time.
Old Nov 13, 2009 | 01:32 AM
Kybel's Avatar
I have the Dodge intank conversion and it puts out a wopping 7 psi at idle and runs at about 5 psi. For the same money get a Raptor or Airdog.
Old Nov 13, 2009 | 07:36 AM
nickg's Avatar
common opinion is it barely keeps up with a stock truck, although they seem to last a bit longer than the engine mounted pumps, its over 800$ to get one locally, I ordered an Airdog (lifetime warrenty ) and had it delivered to my door for 600$ (canadian) I believe you can get them in the states just about anywhere for 499$.
If you can get a "cheap" stock engine mounted pump and have a fuel pressure gauge, you will likely get by for a while...but you will need a fuel pressure gauge!
Old Nov 13, 2009 | 06:57 PM
2500superram's Avatar
put a pump on the frame.the dealer put an intank pump on my truck and wot would pull the pressure down to zero on the gauge.piece of junk in my book.
Old Nov 13, 2009 | 08:38 PM
rigsy340's Avatar
i ran the in tank and engine mounted with a regulater. mine was converted under warranty. price was right.
Old Nov 14, 2009 | 07:21 AM
lovinCTD59's Avatar
The intank pump Really is not worth much to me. I too also added a pump on the frame. I could hardly hold 1-2 PSI with stock injectors and Edge EZ. Now Im able to hold 14 with Bosch 300's and the Quadzilla cranked up.
Old Nov 14, 2009 | 09:11 AM
cumalong's Avatar
I changed the intank out to the fass DDRP and it idles at 17psi and WOT down to 11 psi. It has a 5 year warranty i believe and is about 250.00. If you plan on going in the 400hp plus range, you may want a bigger pump. I am happy with the ddrp.
6 2 Carl
Nov 27, 2010 09:55 AM
Bigsmoke3500
16
Jan 1, 2008 09:32 PM
WhoCares79
Jun 29, 2006 11:41 AM
HMartin
Mar 10, 2006 07:16 AM
BobQ
Jan 3, 2006 05:59 PM
