int. dead pedal
Old Mar 2, 2013 | 06:42 PM
that guy's Avatar
int. dead pedal
hey there! I have a stock '02 2500 with a 24 valve. My throttle is going dead while driving, at idle and in cruise control. it's intermittant. there is no lack of power when the throttle IS working and no misfire so i think the fuel system is good. The check engine light is not coming on but I think it could be an electrical issue. before tossing a bunch of money and parts at is, I'd like to know if anyone lse has ran into this? is the throttle position sensor prone to failure on those trucks?
any advise would be welcome.
Old Mar 2, 2013 | 08:36 PM
lovinCTD59's Avatar
Check your codes.. turn your key on, off, on, off, on... Your odometer will display P Ecu. Followed by any codes.
Does your engine return to idle while driving with the throttle depressed? If it does is say throttle position sensor.
Old Mar 2, 2013 | 08:57 PM
that guy's Avatar
there is a p1653 and a p0500 code.
it doesn't return to idle unless i take my foot out of it while driving.
Old Mar 2, 2013 | 08:58 PM
Checkmate's Avatar
apps?
Old Mar 2, 2013 | 09:15 PM
that guy's Avatar
i'm thinkin apps, but before i spend the $500 bucks i'd like to be a bit more certain.
Old Mar 2, 2013 | 09:30 PM
Checkmate's Avatar
not sure about your year, but mine went bad on my 03 and i bought a retrofitted one for under 200
Old Mar 2, 2013 | 09:34 PM
that guy's Avatar
I'll look into that. thanks eh!
Old Mar 2, 2013 | 11:20 PM
lovinCTD59's Avatar
Do a search for 'timbo apps'. I have used this on several trucks I have worked on with good results..
Old Mar 3, 2013 | 10:25 AM
SIXSLUG's Avatar
A good way to check the APPS is set the cruise. If it stops cutting out or idling down it is not the APPS. The cruise control doesn't use the same system as the APPS...
Look up the codes and see what you have, 1693 is a companion code so its nothing, the 0500 will leeadd you in teh right direction.
Old Mar 3, 2013 | 10:37 AM
SIXSLUG's Avatar
P0500 is a vehicle speed sensor A.
That's where I would start.
Old Mar 4, 2013 | 02:02 PM
drewk88's Avatar
APPS can be had for $139 from pensacoladiesel on eBay
Old Mar 4, 2013 | 05:40 PM
Busboy's Avatar
The Timbo APPS is a much better solution and very reasonably priced.
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
Diesel Freak
May 3, 2003 09:40 PM
midwestdually
Apr 22, 2003 08:46 PM
