Input needed please
Old Feb 2, 2009 | 09:31 AM
BBWD's Avatar
Input needed please
My friend has a 99 dual wheel standard transmission with 160K on the clock. This past weekend the engine started loping (runs smooth for about a minute then lopes about 6 or 7 times, then repeats), smokes (white/blue haze) and has no power.
We checked the fuel for contamination and it was clear.
Next step is to check the fuel pressure. Can someone advise what the fuel pressure should be?
Also, does this sound like the IP dying?
Thanks in advance for the replys!
John (DH)
Old Feb 2, 2009 | 10:29 AM
rebal's Avatar
Fuel pressure should not be less the 5 psi at WOT 10-14 idle next did you change filter? then I would go to auto zone or the likes and see if you can get the codes. 0216 is not what you want to see. that said the problems your having are some of what happens when the VP takes a dump .
Old Feb 2, 2009 | 11:27 AM
RowJ's Avatar
Originally Posted by BBWD
...es this sound like the IP dying? ohn (DH)
Very possible. IP or Lift Pump.
As mentioned, should be 12 psi, +/- 2 psi, at idle. Check codes and pressure! Good Luck!
RJ
Old Feb 2, 2009 | 01:45 PM
Dr. Evil's Avatar
9-10 psi at idle and no less than 5 psi at WOT (that is assuming he doenst have the in-tank dealer "fix").
Follow the advice above.
Old Feb 9, 2009 | 10:19 AM
BBWD's Avatar
Turns out it was the IP. New lift and IP on order. Thanks to all for the input.
John (DH)
Joe Diesel
Nov 12, 2007 08:59 AM
Jordan5687
35
Oct 2, 2007 06:12 PM
thejoker502
Aug 9, 2007 09:39 PM
cumminsman02
Oct 11, 2004 05:09 PM
806 Southern In
20
Jan 31, 2004 09:50 PM
