Injector difference
Old Aug 1, 2005 | 10:42 AM
Mike D's Avatar
Injector difference
Anyone know the difference between the 12v injectors and the 24v injectors?
Old Aug 1, 2005 | 03:52 PM
JDGnut's Avatar
Re: Injector difference
Differences??? not much is the same.... Different angles, different pressures, different bodies, different mounting, one has a line.. one as a feed tube (bullet) .... Maybe the copper washers are the same??? but that's about it...
Bryan
Old Aug 1, 2005 | 03:59 PM
Mike D's Avatar
Thanks. Don't know much about the 12v side.
Old Aug 1, 2005 | 04:17 PM
JDGnut's Avatar
Mike the 12V injector is in the side of the head, and is external... the function is still the same.... when you go to a 4V per cylinder, you normally move the injector to the middle of the cylinder.. on the 12V you can get pretty close to the middle of the cylinder from outside the valve cover.... The trick on the 12V injectors is the that the holes in the injector tip are not inline with the body of the injector, because they are at an angle, but the spray pattern has to spray in to the top of the piston equally... the 24V injectors the holes are in the same location around the injector tip, but because it is centered on top of the piston bowl..
Bryan
Old Aug 1, 2005 | 04:30 PM
Mike D's Avatar
Thanks JDGnut! I get it now. Sometimes, I think to myself "is this a stupid question" before I post it, but in this case I'm sure I'm not the only one who benefited from your wisdom.
G-NOTE
Sep 1, 2005 06:36 PM
ckennedy
Aug 25, 2005 11:31 AM
oscaroc
Apr 2, 2005 12:14 PM
jbs007
Aug 16, 2003 09:51 AM
