Injection Pump Question
Old Jan 18, 2009 | 01:45 PM
dodgedually96's Avatar
Ok My Injection pump is out, and im looking at a few of them i spotted one from Bosch called the Hot Rod Injection pump (adds 80-100 hp) and i was wondering if i could use that with my setup i have but was wondering if it would cause me to worry about my EGT's going through the roof? Also is it a wise idea to change the Lift Pump out when you do the injection pump even if the Lift Pump checks out fine ? (found a 150GPH also)
Im just looking for what would be the best idea on what to do cause i do plan on making more up-grades to my truck anything will help
Thanks
Old Jan 18, 2009 | 03:58 PM
Krob's Avatar
I think the common thought around here is just to get a regular SO pump. The SO pump pushes more fuel then the HO, when you start adding boxes. HO vs SO starts mattering around the 400hp mark if i remeber correctly.
It is cheaper to get power from a box then from a VP that will eventually die anyway.
Id also look at blue chip diesel performance, i believe they make the best reman VP44. They are a little more expensive then the regular ones but from what i understand last longer.
Thats my thoughts
Id see what others say my memory isnt always right.
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
