injection pump pressure
Old Apr 24, 2006 | 10:36 PM
newton's Avatar
at idle i am running between 20 and 25 psi measured at the pump,i just want know if any of you guys feel that this is to much pressure and i should put some kind of regulator on the fuel line. at wot with comp on 5-5 pressure drops to about 13, that i am happy with, but wanted to know if too much pressure going into the pump when not under load is bad for the vp44.
any input appreciated.
Old Apr 24, 2006 | 11:11 PM
Ph4tty's Avatar
So you're measuring your fuel pressure before the fuel filter or do you have an aftermarket setup?
Click on User CP above and edit your signature so we know what you've got
Old Apr 25, 2006 | 12:08 AM
TNutcher's Avatar
Yeah that pressures fine going into the VP44. I'd fell fine pushing 30 or so but not sure about more than 40. TNutcher
Old Apr 25, 2006 | 12:22 AM
oestreich84's Avatar
I am running about 23 at idle, and 19 at WOT. If my pressure at idle was 25 or more, I would have a regulator. I don't think the VP44 is made to handle that kind of pressure, but I could be wrong.
Old Apr 25, 2006 | 09:50 PM
newton's Avatar
i am measuring my pressure at the pump, not before the filter.
so what is the best regulator to put inline, after the pusher pump.
so far i cant seem to find one for this ap.where to get one?
tommurray
Feb 23, 2014 10:38 AM
adgr71
Nov 28, 2005 07:34 PM
AAmeeting
Aug 5, 2005 10:02 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
