Fuel Pressure readings at injection pump
Old Aug 4, 2005 | 07:22 PM
AAmeeting's Avatar
Question Fuel Pressure readings at injection pump
I just replaced the factory lift pump with the Carter Black from Summit. I installed it with the 3/8 line and stock banjo on the fuel filter. The electric quage is connected to a tapped banjo bolt on the pump followed by a 30" stainless 1/8 inch line. This is what it reads, At Startup it fairly slowy climbs to 12 psi. At 60 mph it is around 7-9 psi. Floored it is at 5-6 psi. After it is warm it will Idle at 9-10 psi. Could this be a dirty fuel filter? Bad qauge? Normal? Fuel filter was changed about 6500 miles ago. I though it would peg 15 psi. Any thoughts?
Old Aug 5, 2005 | 12:29 AM
BoostdCTD's Avatar
Hmm, I don't know which model the stock LP is but I know Carter made that one too.
Old Aug 5, 2005 | 06:18 AM
CTD NUT's Avatar
Is the Carter pump a #4601HP? If not, it could be a lower pressure internally regulated unit which would be the wrong pump for this application.
Old Aug 5, 2005 | 09:07 PM
AAmeeting's Avatar
Yeah Its the 4601hp. I changed the fuel filter today and it went up to 14 psi And floored went to 9 as the lowest I drove it for about an hour total. Now on the way home it just dropped back to 9 psi <edit>. I can floor it and touch 3 again. What do I do?
Old Aug 5, 2005 | 09:27 PM
smokindog's Avatar
Originally posted by AAmeeting
What do I do?
You get a new lift pump, that's what you do! Or a FASS, or RASP, or Air Dog.
Old Aug 5, 2005 | 09:42 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Also see this thread........
https://www.dieseltruckresource.com/...threadid=74469
Old Aug 5, 2005 | 09:58 PM
AAmeeting's Avatar
That thread may be it. I left my lights on yesterday and drained them both. But why would it work fine and then out of nowhere not? Does the ecm vary voltage to the LP? Could I use a relay to just give it full power? It would be easy. I will check the voltages of both batteries tommorow at work and post the results then... At work. ha I hope this is it.
Old Aug 5, 2005 | 10:02 PM
AAmeeting's Avatar
I will also check the voltage at the LP.
tommurray
Feb 23, 2014 10:38 AM
BossHogg
Mar 30, 2011 01:10 PM
GlennRMK
Sep 5, 2006 11:24 PM
kawi600
Feb 2, 2006 07:49 PM
cmckinney
14
Mar 4, 2004 09:51 AM
