Idle prob with 4 DTC codes
Old Oct 12, 2006 | 06:41 AM
jaybone's Avatar
New guy here and I need some help. I just purchased a 2003 1 ton C/C 6spd 5.9L. 4x4. 130 K miles and truck seems to run ok and got 20 MPG 250 miles home from Texas.
The issues: Idle goes to 1100 often, normally stays around 850 on first start. I noticed when the idle is high, if you turn on the A/C it comes back down, I tried tapping the throttle, no joy. Hard starting, (takes 5-10 secs to fire up)
I found the following DTC's : 0633,(SKIM Key not programmed)
0602,(control module not programmed/error)
2509 (ecm/pcm power input signal intermittent)
0234 (T/C engine over boost condition)
What if anything do these mean?
I know nothing about diesels, or where to even begin. I know the dealer installed a new battery, and the previous owner had put on a straight pipe exhaust. I am hoping to find out if anything might be expensive to get fixed with out going out of pocket.......if so I will try and take this truck back...Thanks in advance, New guy. Jay, Oklahoma City
Old Oct 13, 2006 | 01:51 PM
Bookdoctor's Avatar
Jay, You didn't happen to buy this truck in Dallas did you? We just got back to Ohio 1058miles with a 2004 that we bought from WFL in Dallas and we are having all kinds of problems with it. It burned a quart of oil on the way home. Have an appointment Monday AM to see what is going on. Good luck to you. Vicki
Old Oct 13, 2006 | 02:00 PM
jaybone's Avatar
Not dallas but close, Commerce TX. Its going to the local dealer tonight to see what they can find on it tomorrow.
Old Oct 13, 2006 | 03:42 PM
nitrousn's Avatar
Maybe not the case but watch for flood vehicles down there after last years hurricanes.
John_P
14
Nov 7, 2009 03:45 PM
John_P
0
May 11, 2009 03:49 PM
LongBlackRam
Dec 8, 2008 04:53 PM
1882
Aug 21, 2006 02:27 PM
R&DDiesel2500
Feb 18, 2006 04:05 PM
