DTC Error Codes.
Old Feb 18, 2006 | 12:57 PM
R&DDiesel2500's Avatar
DTC Error Codes.
I just bought a 1999 Dodge 2500 4x4 CTD. The original owner had programmed the truck with a Hypertech, He had the dealer flash his comp with updates for more positive shifting positions or something like that. Well I found out that a Dealer Flash will blow out the Hypertech tuning, so I hooked up the Hypertech to confirm where the truck was at. But before I could do anything it said I had two DTC's One was a ( P1693 ) and the second was ( P0122 ) I looked around a bit and it seems the 1693 indicates that an error fault was registered in the ECM Is the 1693 pointing to the P0122 which according the info Im getting is a low voltage situation on the Throttle Position Sensor. Any experience you guys have with this would be appreciated..
BTW, I cleared the DTC's and confirmed my Hypertech tuning to the first level, I didnt go max because I'm still waiting for gauges to get here.. Then I will go Max and be able to monitor it ..
Thanks.
Old Feb 18, 2006 | 01:25 PM
phox_mulder's Avatar
Yes, the 0122 is stored in the ECM, and the 1693 is stored in the PCM to let you know there is a code in the ECM.
Two computers don't talk together well.
phox
Old Feb 18, 2006 | 01:41 PM
Should I worry?
What should I do about the P0122 then should I check later to see if it codes again, if so then what?
Old Feb 18, 2006 | 01:50 PM
I'd clear it and see if it comes back.
If it does, start with the APPS reset procedure,
https://www.dieseltruckresource.com/...n&onlynewfaq=1
If that doesn't fix it, there is a lenghthy procedure for setting the voltage, do a search for APPS here, and you should be able to find it.
If that doesn't fix it, then a new APPS in needed, and they aren't exactly cheap,
many have found them on Ebay, but IMHO, buyer beware.
phox
Old Feb 18, 2006 | 02:12 PM
Apps
what is Apps exactly?
Old Feb 18, 2006 | 02:16 PM
Accelerator
Pedal
Position
Sensor.
No physical connection between the "gas pedal" and the engine, fly by wire.
phox
Old Feb 18, 2006 | 04:05 PM
Thanks a lot for your help..
LFD2037
21
Sep 5, 2021 10:28 PM
John_P
0
May 11, 2009 03:49 PM
LongBlackRam
Dec 8, 2008 04:53 PM
jaybone
Oct 13, 2006 03:42 PM
1882
Aug 21, 2006 02:27 PM
