idle adjustment
Old Aug 25, 2005 | 10:28 AM
voo's Avatar
voo
idle adjustment
trying to find the adjustment screw on my '98 dodge I have seen the diagrams for the 12v but I have a 24v. the truck dies at idle when the air is on and the engine is hot. in the past an idle adjustment is all it needed. thanks matt
Old Aug 25, 2005 | 11:27 AM
piperca's Avatar
No idle adjustment on a 24 valve, it's controlled by the ECM.
Old Aug 25, 2005 | 08:51 PM
Stamey's Avatar
You're going to have to look for the bad sensor. It could be a crank sensor, cam sensor, or somethign else. The first thing you should do is check the codes. Your mechanic can do it, or Auto Zone will do it for free.
Chris
Old Aug 26, 2005 | 07:48 AM
Supermod56's Avatar
Yep, messing with the idle screw on almost anything controlled by the ECM is Verboten, you must have a bad sensor as stated above, get the codes read and it should be an easy fix.
FANZDSLPWR
Jul 9, 2004 06:42 PM
apache
Mar 30, 2004 10:17 PM
Timinva
Jun 26, 2003 09:36 AM
Den052
Jun 21, 2003 12:45 PM
Dusty 96
Nov 7, 2002 03:39 PM
