Idle speed adjustment?
Old Jun 26, 2003 | 08:18 AM
Timinva's Avatar
DTR Advertiser
My company vehicule is a 98 12v 2500. When I run the a/c it will stall when I come to a stop. Is there an idle speed adjustment? It is only idling about 600rpm in gear. Truck runs fine other than that. thanks Tim
Old Jun 26, 2003 | 08:50 AM
Rammin On's Avatar
Re:Idle speed adjustment?
Tim ...<br><br>Yes ... is this an auto? If so, 750 is the idle speed in gear with the A/C on ... 600 is too low ... look ) really feel ... the back of the pump where the linkage rotates ... you will feel a bolt with a jam nut on it ... loosen the jam nut and turn the bolt to adjust your idle ... call me if you need help ... 573-265-5595<br><br>Keith
Old Jun 26, 2003 | 09:05 AM
Timinva's Avatar
DTR Advertiser
Thanks Keith, you missed a good time last weekend. Hows your shop coming? Let me know when you have your grand opening, I hear John P and Johner are coming out. Will let you know how the adj goes. Tim
Old Jun 26, 2003 | 09:36 AM
Timinva's Avatar
DTR Advertiser
Keith, got the idle adjusted to 750 in gear. I have adjusted easier things to get to. Thanks for the help. Tim
wurkenman
Apr 29, 2008 06:25 PM
jmd025
Aug 1, 2007 08:52 PM
supersonictoys
Jul 19, 2007 08:35 AM
Dusty 96
Nov 7, 2002 03:39 PM
