idle adjustment
Old Jul 9, 2004 | 07:00 AM
FANZDSLPWR's Avatar
idle adjustment
can anyone tell me where exactly is the idle adjustment on the 96 cummins. the haynes manuel shows it but it does not say where it is.
Old Jul 9, 2004 | 08:44 AM
berner's Avatar
The idle screw is at the back and bottom of the injection pump. There's a 10mm locknut on the bottom of the screw. You have to stand on your ear to get at it.
Old Jul 9, 2004 | 04:31 PM
13FOX's Avatar
The best way to find it is have somebody in the cab press down on throttle back and forth with the engine not running. While they are doing this, look for the movement of the rod that comes from the injecotr pump. You will see it move back and forth. It also comes off with a littlte pressure on the ends. When you losen the lock nuts turn the rod either direction to get the idle you want. The required idle for a 12V is 750rmp's. When you get it set to this idle, drive it for awhile. The idle may drop some or in some cases increase and a readjustment may be needed again. Don't forget to tighten down the lock nuts after you adjust the idle. Hop this helps!
Old Jul 9, 2004 | 06:42 PM
infidel's Avatar
Click this-
http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
FANZDSLPWR
Aug 12, 2004 12:10 PM
apache
Mar 30, 2004 10:17 PM
Timinva
Jun 26, 2003 09:36 AM
Den052
Jun 21, 2003 12:45 PM
Dusty 96
Nov 7, 2002 03:39 PM
