I need some help
Well, I can tell you what I have since I just went through all of this. Stock replacement pump (American made). Key on and pump running, engine off I have about 16 lbs. That is going to be the bypass valve pressure. Running at idle I have about 14 lbs. and WOT I have 12 lbs.. All of this is measured on the outlet side of the filter with a 30lb. gauge mounted directly to the filter housing. If you are using a gauge with any higher capacity than 30 lbs. you will not get an accurate reading that low.
Those are my figures, others may vary.
Rick
Rick
bsj04
Sep 20, 2007 08:09 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
