Hunting Transmission fix
Old 04-29-2012, 03:56 PM
daddy mopar's Avatar
I have been on this site for 3 years and have read all of the fixes for the hunting transmission. Foil, Noise isolators, wire routing, battery connections . . . . . bla bla bla
Seriously why did I not listen to some of you guys and buy the APPS noise isolator? Best money I have spent on the truck so far. Could have saved so much headache and frustration (possibly my transmission) in the last three years !
Anybody who is having the shifting headache buy the noise isolator!
http://www.genosgarage.com/ BD-1300030 APPS NOISE ISOLATOR ('94-'04) $23.75
Hooked it up this morning and Shifting =
Daddy Mopar and Black Tornado gna have to drive into the sunset tonight!
Old 05-03-2012, 03:35 PM
McCallHoser's Avatar
How hard to hook up?
Thanks
Old 05-03-2012, 07:39 PM
whiskers's Avatar
Tap into one wire and hook the other lead to ground. 5 minutes.
Old 05-08-2012, 09:38 PM
Extremely easy to kook. Push a needle through a wire, and then attach the wire connected to the needle to the fire wall. Basically that easy.
Old 05-09-2012, 08:54 AM
phal's Avatar
I did it years ago
I installed one years ago. Once a year I had to clean the Apps Filter ground when it came back. It was always winter when the problem popped back up.
Then last winter nothing I did would fix it. I changed the APPS sensor and everything is good again.
gary
Old 05-09-2012, 08:45 PM
GUY1996's Avatar
from GUY1996 in fl.mayo9 2012 where do you mount apps noise isolator and where can they be purchased. thanks
RamToughCowboy
08-25-2007 11:14 AM
Rauschbo
05-05-2007 04:48 PM
lumpy_63
19
07-21-2006 09:37 PM
xp8103
13
06-09-2006 05:21 PM
Quick Reply: Hunting Transmission fix
