How do you reset APPS ???
Old Jul 31, 2006 | 11:57 PM
Derek Roch's Avatar
Question How to reset APPS ???
How do you reset the APPS... I have a 2001 with a rough idle with a p0221 code....thinking this could be the problem....
Old Aug 1, 2006 | 12:00 AM
Derek Roch's Avatar
Question How do you reset APPS ???
How do you reset the APPS.... I have a 2001 with a rough idle and a p0221 code....thinking it could be the problem but dont know how to reset it.
Old Aug 1, 2006 | 12:15 AM
Dr. Evil's Avatar
Take a look in the 24V drivetrain TECH FACTS section at the top of the page
Old Aug 1, 2006 | 12:57 AM
roberts11260's Avatar
code
I also have the same code on my 01. You can reset the apps?
Would love to know how.
Old Aug 1, 2006 | 04:47 AM
jrs_dodge_diesel's Avatar
This is a procedure on how to do the reset in our Tech Articles. Click here.
There is another procedure that involves calibrating the actual sensor itself with a volt meter. I'll see if I can dig that one up too.
Old Aug 1, 2006 | 06:31 AM
crobtex's Avatar
From the DTR Tech Facts FOUND HERE
This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Old Aug 1, 2006 | 10:21 AM
how to
Ok
I read it
thanx
supr
18
May 21, 2007 09:29 AM
trex
16
Nov 14, 2005 09:45 AM
Luckycharm1
Sep 4, 2005 04:57 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
