6 speed tranny
Old Aug 1, 2006 | 12:37 PM
MADMATT's Avatar
6 speed tranny
what causes the truck to roll back on a incline when its in gear is it getting loose and old? what needs to be done to fix?
Old Aug 1, 2006 | 01:59 PM
dieselrob's Avatar
Whens its rolling in gear what gear are you in? Is the engine turning to, like if you parked a 4 cylinder on a steep hill and it would creep away becuse the compression wont hold it. I dont see an aftermarket clutch in your sig, does your clutch slip while driveing because you do have a good bit of hp there the stock clutch should be hurtin? Most likely your clutch is sliping and thats why is movin.
Old Aug 1, 2006 | 02:02 PM
MADMATT's Avatar
sweet that does make sence i do have a after market clutch in and it has slipped time to time its a luk pro gold not sure what kind of power they can handle
Old Aug 1, 2006 | 02:06 PM
HOHN's Avatar
I don't know what Luk claims for power handling, but I'm quite certain that it's pretty mild, as their cerametalic is their higher performance clutch.
It's a pretty safe bet your clutch has had its limits exceeded.
jlh
Diesel4blood
Jul 21, 2014 04:23 PM
Black Dog
Dec 3, 2009 08:18 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
