Hooking up boost gauge
Old Jun 16, 2003 | 06:14 PM
Gene007's Avatar
I have looked through the forums but cannot find the info on installing the boost gauge (know its there, just can't search it out). Have the actual gauge hooked up but where do I hook up the hose from the gauge? I have also read that the EZ blocks the over boost code, I have a box from BullyDog, does anyone know if they do the same? ???
Old Jun 16, 2003 | 07:09 PM
tlea7's Avatar
Re:Hooking up boost gauge
Look to right of fuel filter and slightly higher (next to MAP sensor) You will see a pipe plug with a 1/2&quot; square drive. You will have to use adapters to get it down to your fitting size, usually a trip to hardware store will to it. Start with 3/4&quot; NPT out of block and go from there. And yes bully's box does same thing.<br>Tim
Old Jun 16, 2003 | 09:50 PM
Gene007's Avatar
Thanks tlea, Appreciate the info. Looking at your profile, you have a Turbo-master (assume)boost controller. What is your boost psi. Did you see a difference in performance. I will be installing mine shortly. <br><br>Gene007<br>WarWagon
Old Jun 17, 2003 | 02:08 AM
KATOOM's Avatar
You can also call up Piers. He sells a bolt that replaces a manifold bolt and has the air hose fitting built in. I went the other route, but I hear the bolt trick is good too.
EverydayDiesel
Jun 18, 2007 04:16 PM
Dodge12vKing
Nov 19, 2006 04:37 PM
ckennedy
Nov 11, 2004 12:02 PM
smokin_dodge5_9
Oct 17, 2004 03:23 PM
USCGtraveler
Aug 7, 2004 06:15 PM
