hooking up a air vacuum gauge...
Old Nov 11, 2004 | 08:54 AM
ckennedy's Avatar
hate to ask... but any input on hooking up a air intake vacuum gauge... Best location... how exactly is it done... just tap a line and seal it???
Old Nov 11, 2004 | 08:58 AM
DF5152's Avatar
are you talking about a vacuum/boost guage or strickly a vacuum guage?
At any rate try finding a boots bolt and use that no drilling required.
genos garage has them as well as some others.
Old Nov 11, 2004 | 09:02 AM
ckennedy's Avatar
strickly a vacuum line on the air filter sytem (somewhere)... guess you would just "drill" for the boost bolt placement...
Old Nov 11, 2004 | 09:06 AM
DF5152's Avatar
depends where you want to mount it on the intake plenum before the turbo? the boost bolt is designed to replace and intake manifold bolt and allow a boost reading....why do you want a vacuum gauge
Old Nov 11, 2004 | 09:14 AM
ckennedy's Avatar
thanks... that is what I thought on the boost bolt... as for why do I want a vacuum line... basically for the H### of it... at some point I am to change to a donaldon dry air intake systemmm and saw they had a intake vacuum line gauge that looked pretty cool.. plus I may have a extra hole for a gauge to mount...
before the turbo... for the air filter system..
Old Nov 11, 2004 | 11:57 AM
Ray Roton's Avatar
I wanted to replace the "filter minder" with a dash mounted vacuum gauge so I could monitor the condition of the air filter. Problem is, I can't find a gauge sensitive enough.
Old Nov 11, 2004 | 12:02 PM
ckennedy's Avatar
ray - have u tried one yet?? what have you looked at???
heavyboostin
21
Jan 28, 2005 10:41 PM
SandAddiction
Nov 25, 2004 08:01 AM
smokin_dodge5_9
Oct 17, 2004 03:23 PM
USCGtraveler
Aug 7, 2004 06:15 PM
Gene007
Jun 17, 2003 02:08 AM
