Here's A Code For Ya
Old Feb 24, 2007 | 08:20 PM
Ridiculous's Avatar
P 0500 No Vehicle Speed Sensor Signal
what does this really mean?
it didn't happen until i put it in 4LO to get up my driveway. (its a steep one) and it's snowing here like you wouldn't believe, i guess they got interstates shut down and everything, its a white out.
Old Feb 24, 2007 | 08:58 PM
can17's Avatar
I get that code whenever I spin my tires a lot or if I idle my truck high on cold mornings. It doesn't hurt anything and goes away after so many starts.
Hope this helps.
Old Feb 24, 2007 | 09:22 PM
Ridiculous's Avatar
just so long as it doesn't hurt anything. its just the first time it's happened, i cleared it with my smarty and i'll see if it happens again.
anyone else have anymore info on this.
Old Feb 24, 2007 | 09:38 PM
cLAYH's Avatar
If you spin the tires alot the wheel speed sensors for the ABS get confused and think they are bad. They're not they're just reading different wheel speeds cause you are spinning the tires.
As said above it doesn't mean there is a problem and will go away on its own. I had mine come on last week after getting stuck at my dad's acerage.
Old Feb 25, 2007 | 01:39 PM
zulusafari's Avatar
Yep. Keep an eye for it. If it goes away, then it was the spinning. I had that one here last week bustin' through drifts on may home from work. I also had my ABS light come on for awhile until I went for a drive the next day without spinning alot. At first I was scared I broke something, but then rememberred I had been spinning 3 wheels sometimes. Meeses up the ABS computer.
Old Feb 26, 2007 | 08:41 PM
matthopp's Avatar
I have been getting the 0500 code along with 1693 and 1694 a little lately. No noticible problem and it only stays on one cycle of the truck. Doubt i would have been spinnning my tires. Not sure whats going on.
Old Feb 26, 2007 | 08:50 PM
dodgediesel's Avatar
Don't worry about it unless your ABS light keeps coming on in conjunction with that. That would mean a bad wheel hub. 99% sure it is from having so much Cummins power and burning off those rear tires!!!! Cummins=too much power=spinning tires=0500....
Old Feb 26, 2007 | 08:54 PM
jr22's Avatar
I also have a p0500 code it for the rear speed sensor. it will turn on the abs light and then go out there is a ohm spec for the sensor. we my abs light comes on the speedo quits working. Mine had a crack in it. It cost $27 at work havnt had a problem since good luck, jr
steelydan
Dec 25, 2005 01:59 AM
CTD NUT
Apr 5, 2005 04:45 PM
Dieseldude4x4
Dec 23, 2002 08:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
