Help with starting?? somethins wrong
Old Feb 9, 2009 | 06:37 AM
lvmknsmoke..'s Avatar
ok my truck just started doin this.. il turn on key til wait to start light goes off then i turn key and just here a click try again stil same.... it usually starts after 3 or 4 or more attempts it wil just fire like normal.... couple times right after it started my radio wouldnt work for a minute... anyone know wats up?? o and my comp wont change levels either right after i start it sometimes... thanks..
Old Feb 9, 2009 | 06:39 AM
madhat's Avatar
Administrator/Jarhead
First thing I would do is clean my battery contacts. Then, I would start looking at my ground contacts. It just sounds like a bad connection.
Some coke and a wire brush on your terminals will do wonders...
hth...
mad
Old Feb 9, 2009 | 06:48 AM
mishkaya's Avatar
What madhat said, and you might want to check your starter contacts as well while you're at it, makes for cheap preventative maintenance. I recommend Larry B's contacts...
mishkaya
Old Feb 9, 2009 | 07:27 AM
ok that explains that but... now on way to work i had dead pedal halfway there before it cleared up had a irratic idle an lack of power only a companion code showing vp?
Old Feb 9, 2009 | 03:21 PM
madhat's Avatar
You'll have to get the 2nd gen guys to chime in on this one...
Old Feb 9, 2009 | 03:31 PM
McCanick08's Avatar
Maybe your starter solenoid is going bad. I'm not certain if this could be it but a clunk or click is the noise for that @_@. Then again the bad ground idea seems more likely with the radio not working
edit: whoop sorry jumped on the first part a bit too quick didn't look at the following posts
Old Feb 9, 2009 | 05:27 PM
mishkaya's Avatar
I still think you have a bad ground somewhere causing all these problems. I would highly suggest cleaning all grounds under the hood (not just the battery connectors) as a first step. Also, are your batteries charging properly? Are they still good? Start with the basics first.
mishkaya
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
J.A.F.O.
Sep 12, 2003 08:03 AM
Jack Thorpe
42
Jul 10, 2003 12:25 AM
