Water Pump
Old Feb 2, 2009 | 07:59 PM
GreatTruck2001's Avatar
Water Pump
Can anyone give me some telltale signs of a failing waterpump? I don't notice any weeping/dripping anti-freeze, but there is a little fore/aft play. What kind of life does the stock pump usually give?
Thanks!
Old Feb 2, 2009 | 08:02 PM
robert78.5's Avatar
I belive there should be zero endplay.
Old Feb 3, 2009 | 10:07 AM
dozer12216's Avatar
I also believe there should be zero end play on shaft of water pumnp on a Cummins diesel. Are you talking about fan??
Old Feb 3, 2009 | 08:42 PM
Kennys's Avatar
Don't know about how long most are lasting but mine has 408K. Haven't noticed any problems with the original, yet. I do have a new one ready.
Old Feb 9, 2009 | 10:36 AM
Swarthy Dago's Avatar
good idea, you have the tools with you too ? I got lucky and had the tools with me, did it on the HWY 5 south of Salinas.
Old Feb 9, 2009 | 09:43 PM
Beefdoc's Avatar
Just replaced mine this weekend, 315K. It had a small amount of end play, but I replaced it because it was leaking. It appears that it was leaking around the o-ring gasket on the bottom. Corrosion/rust had worked it's way between the o-ring and the block. The block surface where the O-ring mates was pitted pretty bad, so after cleaning it up well, I used a little silicone on the O-ring when I installed the new one (just to make sure). I bought the new (not a reman) pump from our local O'Reily's, lifetime warranty for a bit over $60.
As far as end play, it should be zero. It you have end play change out the pump. I've had water pumps with very little end play take out the seal, lock up and send the fan into the radiator on other vehicles and tractors.
FWIW
Matt
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
