Help!!! NV5600 tranny
Old Sep 2, 2007 | 03:45 PM
DMAN99's Avatar
tranny locked up toof it out and started to tear it down and I can't get the front of of it to come off. What am I missing?
Old Sep 2, 2007 | 05:10 PM
gmctd's Avatar
Dude, yer in way over yer head - gots'ta pull the tailshaft housing, undo some bolts, clips, gears and stuff back there - the entire gear-train, incl the shift-rails and tailshaft, pulls outta the 150lb cast-iron case - should say, the trans is positioned vertically on the front bellhousing surface, then the gear-case is pulled up and off the gear-train - very complicated process, particularly with that 150lbs of cast-iron you'll need to lift and manipulate around the shift-rail bosses in the case - prolly best to head down to yer local trans shop, see if they have one apart, so you can see what is involved
Old Sep 4, 2007 | 05:13 PM
DMAN99's Avatar
got it apart now I was wondering if there is a kit for all the bearings or if I just need to find each one of them individually?
Old Sep 4, 2007 | 08:03 PM
blackdiesel's Avatar
Registered
Yes there's a bearing kit for it. I have seen them on ebay. and quad 4x4 has them also. That bottom shaft (3-4 gears) takes 40 tons of pressure to disassemble. If your just doing bearings it won't have to come apart, but to get to the syncros it will.
Old Sep 4, 2007 | 10:07 PM
PourinDiesel's Avatar
Originally Posted by blackdiesel
Yes there's a baering kit for it. I have seen them on E-BAY. and quad 4x4 has them also. That bottom shaft (3-4 gears) takes 40 tons of pressure to disassemble. If your just doing baerings it won't have to come apart, but to get to the syncros it will.
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
Old Sep 5, 2007 | 06:45 AM
gmctd's Avatar
Doesn't take 40tons to remove the gear - can be done with a 5ton gear puller with extensions - the suggestion for a large-size press is because of the length of the shaft and the width across the bed, required to clear the gears.
Good job on getting it apart - it's not yer typical 'pop the cover and push the shafts out' type of job
Old Sep 10, 2007 | 07:47 PM
DMAN99's Avatar
Just got all the bearings for $109 from napa. Timken brand
Old Sep 11, 2007 | 12:24 AM
mj007's Avatar
It don't get better than Timken.
Dr. Evil
Apr 1, 2017 02:54 PM
MikeyB
34
Oct 24, 2014 05:33 AM
roadranger
Sep 14, 2004 05:10 PM
K2Cummins
Jun 6, 2003 12:18 AM
MikeyB
Apr 12, 2003 12:31 PM
