Help Injector selection
Old Oct 12, 2010 | 10:01 AM
blh1960's Avatar
I am pushing 170k on original injectors. At least I think they are original. How do you know if you have stock injectors? Anyway with the mods I have on my truck, what stage of injector can I get away with? I am running a airtex 7153 lift pump. 16psi idle, 12 wot. I do have a different turbo with the banks setup. I run 40+ boost when I get on it. The truck takes awhile to spool up. Seems to be starving for fuel. I am think a rv275 or ddp 50hp injector. Am I about right? My tranny has a aftermarket converter but basically stock. I think my fuel system is going to keep me in the stage 1 to stage 2 area. Tranny also is a weak link.
Old Oct 12, 2010 | 04:23 PM
johnh's Avatar
i wouldn't go any bigger than stage 2, stage 3 will give you more smoke and higher egts than you would care for
Old Oct 13, 2010 | 08:53 AM
high bid's Avatar
Mach 1.6!!!
Old Oct 14, 2010 | 08:57 AM
blh1960's Avatar
I am thinking stage 2 myself, maybe even the rv300 injectors.
Old Oct 14, 2010 | 10:03 AM
Tate's Avatar
No such thing as RV300's, they are just the 275hp injectors.
Old Oct 14, 2010 | 01:24 PM
blh1960's Avatar
thanks for clearing that up.
turbomustang
Apr 15, 2011 09:42 PM
jgiachino
Apr 16, 2009 12:40 AM
chw
18
Dec 31, 2008 05:10 PM
Hoser795
Sep 9, 2008 01:45 PM
dnrhorst
May 1, 2008 08:50 AM
