help ff change no start
Old Feb 22, 2003 | 08:57 PM
roadrat's Avatar
Did first fuel filter change today, truck won't start :'( I think the lift pump is shot, maby it has been for a while and this filter change just brought it to light. no fuel pressure anywhere. I took the fuel line off where it comes into the filter canister and bumped the starter several times, the pump was buzzing away but no fuel comming out. Am i on the right track here, or is there something i am missing? I filled the canister with filtered fuel before putting in the new filter and the truck started and ran for a few seconds then died. It has 50,000 miles on it. <br> <br> rob <br>
Old Feb 22, 2003 | 09:03 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:help ff change no start
Sounds like a correct diagnosis to me. [undecided]<br>Have you tried removing the fuel cap?<br>Good luck.<br><br>Ed<br><br><br>
Old Feb 22, 2003 | 09:05 PM
rich's Avatar
sounds like a lift pump problem. you should change the filter every 12 to 15k not every 50k thats probably why it died.
Old Feb 23, 2003 | 06:49 AM
Tiny's Avatar
I changed my fuel filter and had to fill the canister prior to starting. I bumped the starter to fill the canister and it would not. Once canister was filled I hit the starter a few times and she fired right up. Have no gauges yet, but I think I had better get one fast.
Old Feb 23, 2003 | 08:45 AM
roadrat's Avatar
Rich cowboy-I should have been more specific, i have had the truck for only one month, and while doing first oil change thought i would change the fuel filter at the same time. If it is the pump, and i'm sure it is, this could have been a blessing in disguise because the truck was running and starting perfectly,even in very cold weather. fuel mileage was also very good at 21 mpg highway-( Canadian gallon that is )<br><br> rob
CoolumConst
Oct 11, 2008 10:00 PM
markm4
Jul 29, 2007 11:16 AM
jlells01
Sep 1, 2004 08:42 PM
dctoner
Aug 10, 2004 04:00 PM
doitl8r
Jun 4, 2004 11:14 AM
