Help! Anyone Know How to Adjust Throttle Pressure
Old Apr 3, 2008 | 06:33 PM
Dalydrvr's Avatar
I goofed and took the throttle pressure adjusting screw out of my valve body. The shop manual describes a special tool to reset it. Anyone know the dimension of the tool? It bottoms out the valve and then you tighten the screw so it just touches the tool.
Old Apr 3, 2008 | 07:22 PM
Fishin2Deep4U's Avatar
I don;t know the tool dimension, you might try one of the tranny shops.
I would bet that you are going to need a pressure gauge to get it right.
Dave
Old Apr 7, 2008 | 10:26 AM
Dalydrvr's Avatar
In case anyon else ever runs into this...I called Transgo and he suggested that I set the underside of the head of the throttle pressure screw 0.920 above the bracket. I did and it works fine.
Old Apr 7, 2008 | 03:08 PM
dozer12216's Avatar
The tool is .625 inches long. I found a barrel bearing the right length and welded a rod to it.
Dustin450
Dec 27, 2009 10:11 PM
fahtb0y
Aug 4, 2009 09:42 PM
jeffs07mega
Feb 24, 2009 02:47 AM
RonP
Feb 12, 2006 06:12 PM
