Hello
Old Apr 17, 2010 | 07:41 AM
Ben R. Scott's Avatar
Hello
I slammed on my brakes to miss a collision . And afterwards my truck wouldnt rev over 1,500rpm and would only go 35mph. Missing bad after that. Some one said fuel pump cannister could have broke loose. I'm hoping it's just a piece of dirt in the filter. Anyone have this problem?
Old Apr 18, 2010 | 02:20 AM
DIESELWRKS's Avatar
confused on this one. are you having a harder time starting the truck now. have you checked your filter. what year is your truck may help more auto, manual etc. the rpm issue stumps me. let us know what you have looked at or what you think you notice.
Old Apr 18, 2010 | 12:59 PM
trailrydr9's Avatar
Have you turned the key 3 times to read codes? Or taken it to a place that can read the codes for you?
Old Apr 18, 2010 | 11:02 PM
The truck still fires right up. How do you check the fuel filter? I opened the valve on the side of the filter and diesel comes out. I reset the comp by taking off the neg cable for a couple of minutes. I changed the fuel filter still no change. The codes read that I may need to replace the fuel injector pump vp44. Just trying to make sure before I do this.Is there a fuel pump in the tank? Or any other filters on this model. It's a 1998 24 valve , manual tranny, .
Old Apr 18, 2010 | 11:43 PM
dozer12216's Avatar
have codes read at parts store. Your's will not display codes in odometer.
could you have jarred wiring and caused to short?? Check all connections for damage/cleanliest/tightness.
Old Apr 19, 2010 | 02:56 PM
Changed fuel filter still the same. Is there a filter somewhere else in line or in tank. Are the fuel pumps in the tank or on the frame rail. 1998 dodge diesel 24 valve
Old Apr 19, 2010 | 04:41 PM
Codes were p1688 and p0251
Old Apr 19, 2010 | 04:42 PM
Copenhagenjunkie's Avatar
Unless the lp was moved prior to you owning the truck, the stock location in on the drivers side of the engine. Here is a diagram: http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
Old Apr 19, 2010 | 05:48 PM
sheriffav8r's Avatar
Those codes sound expensive....
hdm48
Feb 12, 2003 07:14 PM
Jan 21, 2003 03:23 PM
Farmall
Dec 20, 2002 05:54 PM
Dec 14, 2002 01:21 AM
Palmetto_kid
Nov 23, 2002 04:54 PM
