Heater grids
Old Sep 9, 2008 | 05:52 PM
chuckybones's Avatar
Heater grids
does anyone know if the heater grids can go bad or are there any solenoids that go bad, mine come on when its 90 degrees out, I can tell because when I start the truck my batteries drain down and I can see my rpm's go up and down . I disconnected them and i have no problem, but it's gonna get cold soon .
Old Sep 9, 2008 | 06:59 PM
WestTN's Avatar
Check your Intake Air Temperature sensor.
Old Sep 9, 2008 | 07:15 PM
dozer12216's Avatar
A IAT sensor reporting cold temp will make cycle on. Follow the wiring back from manifold and you will find two heavy duty relays that control current to heaters. The relays are controlled by PCM, based on ambient, coolant and IAT.
Old Sep 9, 2008 | 08:28 PM
robert78.5's Avatar
They will come on when first started at any temp, as long as they quit cycling after the engine runs for a few minutes.
Old Sep 10, 2008 | 12:05 AM
nickg's Avatar
not true for my truck as they only cycle when its cold out, warm temps like now they do not come on...period.
Old Sep 10, 2008 | 12:38 AM
Diesel Doc's Avatar
I had the same problem a while back. New iat and no more grid cycling
Old Sep 10, 2008 | 08:04 AM
sounds like that is what it is the iat. will try it this weekend.
thanks
drydocked
14
Nov 10, 2007 12:45 PM
blazinchuck
Nov 27, 2006 02:46 PM
Bobcat698
Feb 23, 2006 09:10 AM
Mule Skinner
Jan 8, 2005 09:22 AM
KATOOM
Jan 5, 2005 09:40 PM
