The heater grids??
Old Nov 26, 2006 | 07:32 PM
blazinchuck's Avatar
Question The heater grids??
I just got this '94 ram 3500 CTD. Some mornings it runs great and some not so great. This morning it was plugged in and the light went out pretty quick,started perfect-ran great. This afternoon(6pm) I got off work and the light went out about the same as this morning, but once it started-it sounds like its only running on a few cylinders and really smokes white-blub smoke. I haven't checked the batts yet, but could the grids be messing up? where are these things and is there a way to check them? Never owned a diesel before, so any info would be helpful,thanks..Chuck
But on another note,when its running right-it runs
Old Nov 26, 2006 | 07:52 PM
TIMMY22's Avatar
my guess is fuel lines. could be overflow valve or lift pump too. air probably in system. use a short piece of clear hose on return and look for air.
Old Nov 26, 2006 | 09:20 PM
Racing_Joe66's Avatar
mine does the same thing. warmer day it only last for maybe 5-10 seconds and i have to keep my foot on the pedal for awhile or it will quit. but when its colder it really smokes and idels rough even with my foot on the gas for probably a minute or so.
what can cause all this?? i know the fuel pre-heater is fried and i have to replace that. could this be causing it??
thanks
Old Nov 27, 2006 | 10:04 AM
infidel's Avatar
No, the heater is to "melt" gelling fuel so it doesn't clog the fuel filter.
Both of you guy's problems sounds like normal cold weather characteristics to me.
Old Nov 27, 2006 | 10:28 AM
i never had this problem with my 95 i had. only this 97. plus i only get from 9-11 mpg no matter what. towing or not.
Old Nov 27, 2006 | 02:46 PM
berner's Avatar
White smoke at startup is sometimes caused by retarded timing.
The Haynes manual has an excellent section on diagnosing problems with all of the the grid heater components.
cheapskate
Jan 7, 2008 11:15 AM
drydocked
14
Nov 10, 2007 12:45 PM
Bobcat698
Feb 23, 2006 09:10 AM
Mule Skinner
Jan 8, 2005 09:22 AM
KATOOM
Jan 5, 2005 09:40 PM
