Heater Grids/ Fuel Pressure Guage
After starting cold engine with the grids cycling I noticed the fuel pressure guage would drop about 4 lbs when the grids are on and when they cycle off the pressure comes up that 4 lbs. Is this normal?
Thanks for any info.
The grids pull a total of 190 amps. It's very possible that the voltage drop during the cycle causes the LP to slow temporarily thus lowering the pressure.
Mule,
Sounds about right compared to my 98.5
On top of the electrical draw, the ECM/goveror tries to maintain a set RPM. This means a call for fuel to compensate for the alternator load.
More fuel = more flow demand from an already challenged LP = less pressure
Stack the 2 together........
jm2cw
jm2cw
Mine drops also, then when its done cycling it goes back to 14-15PSI.
I've also noticed a pressure drop when the fuel is really cold (-5F ). Then when you fill up its right back up to 15PSI.
Originally posted by Tom
Mule Skinner,
My fuel pressure also drops somewhat on cold mornings, when the grid cycles on and off. Mine seems to stops when I reach about 15 MPH
Tom
Mule Skinner,
Tom
Originally posted by Fueling around
PCM cuts grid heater function at 15 mph road speed.
Bobcat698
02-23-2006 09:10 AM
