heater core flow direction?
Hi, again, It's suppose to be warm here and I have a "weak heat" condition, among other things on a early 98 12 valve. I can hear a change in the blower's pitch when I go from Cold to hot on the heat control, so the mixer door is working. I believe the core has, probably, Bars leak in it, and is partially plugged. I want to back flush the core and would like to know which of the hoses is the hot supply and which is the return? So I can dislodge the obstruction and not put it through the core, some more? I believe the way the coolant flows, on the bottom of the core is where the debris is? I also have a hot wire from the + through a add-on fuse a 20 amp fuse that blows out, I have a 25 in it and seems to be holding for now. How much amps does the blower motor pull on high? And Dodge uses the - to control blower speed? Through the resistors? And blower speed control ****?
Shorts
Nov 6, 2012 10:13 AM
dodgetech77
Jan 31, 2006 03:16 PM
