Coolant flow through heater core?
Does it matter which direction I have the coolant flowing through the heater core? I can't think of any reason why it would matter, and as of now I have it flowing the opposite way from stock and it seems to work fine.
I picked up a vacuum operated bypass valve from a caravan and the only way to really get it to plumb in and be oriented right is to have the coolant flowing the opposite direction from factory.
Thanks, Aaron
Thanks, Aaron
Should be fine. Just check the condition of the coolant periodicaly incase the reverse flow knocks some junk loose in the heater core.
I also put one of those kits from cummins that replaces the freeze plug in the back of the head and allows coolant to flow out the back of the head.
I installed a "T" with a 2lb. check valve and a manual shutoff valve south of that in the heater circuit after I found it impossible to find the correct heater valve for my '71 Chrysler. Works great. Valve open in winter, water flows through the entire circuit, including the heater core. Valve closed in summer, water flows only through the coolant filter portion of the circuit.
On a new heater core it won't matter as much, but on your 20 year old unit, it will. Flow in is the passenger side hose, out is d-side or closer to engine. If unsure, just follow the hose from the t-stat area to the core and the hose where it returns the coolant to the block.
Why ??
Is there an internal design reason for this ??
Yes, our heater cores are designed like a radiator with an inlet and outlet. In via the top, out via the bottom. Hook it up the opposite way the old core could be plugged or at the very least have much more resistance that way. Take a new heater core, shoot compressed air through each tube. You should be able to hear a change in the tone of the air, indicating a higher resistance to flow one way. At least in my experience
Well so far with it being hooked up backwards the heat has been working normal in the mornings. So I think i'll be leaving it like it is unless someone has had an experience that indicates this will be bad.
Thanks for everyone's replies.
Aaron
Aaron
Last time I looked, the heater cores were of the cross flow design.
