have EZ want edge comp?
Old Dec 29, 2002 | 07:28 PM
whiteknight's Avatar
I got the EZ now and would like to go to the edge comp, Im getting gauges in 2 days. is the comp what it says it is? [undecided]<br>(hp/ torque to r.w) and will it effect vp-44? I also know the clutch will need surgery, will the mpg stay the same if i drive it like a human being(staying out of throttle)? any fans of the edge comp or complaints? please help so we can all drive up the passes together. (ahead of chevys and ferds naturally )will the 5spd tranny hold up?
Old Dec 30, 2002 | 04:06 PM
moneyman's Avatar
Re:have EZ want edge comp?
I have the edge comp on my truck which is an 01 automatic and love it. My cousin has a 99.5 five speed and loves his. He hasn't done anything with his clutch and it works just fine. He does a lot of towing and when he tows he tows on level 2. It plugs in just like the EZ but it also has a wire that attaches to the pump. You can run it with or with out the pump wire hooked up. If you run it with the wire unhooked it is just like running the ez. If the wire is hooked up hold onto your pants cause you'll really fly
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
