Grid Heater Cables
Old Feb 18, 2025 | 02:03 AM
Midnite's Avatar
Grid Heater Cables
I need to replace my high current grid heater cables on my 2000 truck. Are there any good, recommended sources these days?
The searching I've done has come up with a set on Ebay that looks good, but of course I can't inspect them.
Any good sources folks could recommend?
Thanks,
Mike
Old Feb 25, 2025 | 04:11 PM
SIXSLUG's Avatar
I only ebay truck parts from Thoroughbred Diesel and the likes. Or you could have the local cable shop crimp up a set....
Kurt
Old Mar 19, 2025 | 02:24 PM
Marine's Avatar
Veteran: Marine Corp
Kurt
This is what I would do as well.
Old May 1, 2025 | 11:54 PM
Midnite's Avatar
I was in a gambling mood and decided to try out the Ebay cables I mentioned earlier and see what they're like. I'm writing up a quick summary here, and including photos of them as I received them.
The quality actually looks very good. The company claims to be a domestic, family owned company, and it definitely appears that these are not some goofy Chinese wonder cables. There appears to be good quality heavy heat shrink tubing on the connectors. The entire length of all cabling is covered in split loom. The terminals had good quality boots. They didn't appear to cheap out on anything. I guess the only possible criticism I might have is to have copper connectors instead of what appear to be zinc plated (?). Honestly I'm not concerned about that though.
I hope the photos I've included are high quality enough to show small detail. Note that even the short ground cable has split loom.
This company is custombatterycables.com. I only happened to stumble onto them on Ebay, but from what I've seen so far I wouldn't hesitate to order from them again. Their quality definitely is better than most I've seen.
I have no affiliation, just fyi.
Mike
Old May 2, 2025 | 12:08 AM
Midnite's Avatar
I haven't yet installed these, but I'll follow up again here when I do.
BearKiller
Oct 18, 2010 04:23 AM
Floridacracker
15
Jun 29, 2008 04:06 PM
Billm2004
15
Oct 7, 2007 09:26 PM
rbrettctd
Jul 22, 2007 01:37 PM
