grid heater Q??
Old Jun 28, 2008 | 07:48 AM
Floridacracker's Avatar
grid heater Q??
i don't need it has anyone just knocked everything out of it and smoothed it out
i live in sw fl
Old Jun 28, 2008 | 08:06 AM
0lywrench's Avatar
yeah somebody on here did,but a grid heater delete from glacier or someone else is fairly cheap and easy
Old Jun 28, 2008 | 08:18 AM
i don't really wan't to buy anything
Old Jun 28, 2008 | 08:37 AM
madhat's Avatar
Administrator/Jarhead
I dunno if it will work, but if you don't want to buy anything, take the heater out, knock the fins out, smooth everything out, and put it back in...
Old Jun 28, 2008 | 09:01 AM
hey mad what do u mean by it won't work ???
Old Jun 28, 2008 | 10:46 AM
madhat's Avatar
Well, there is power going to the grid, right? Probably a sensor, too, telling the computer if it is working or not (if the circut is complete or not). If you remove the fins, it might pop a code.
I would: Remove the power line going to the heater grid and isolate it... remember, there is a lot of juice going to that thing...
Drive around for a day or two, see if it throws a code. If it doesn't, rip them out.
If you rip them out, before you button everything down again, put the heater back on and turn the key on. (before you put the manifold back on) (Don't start the truck) Make sure nothing bad happens. I'd use 2 people, so that they could cut the power quick. If nothin happens... you're good...
DISCLAIMER!!!
1st, I'd price a new grid heater, just incase when you pull the fins out, it jacks something up. If it's not worth it to ya, then...
2nd, Remember that you'll be working with the top of the intake off... if something falls down in there... it'll be bad. I usually use a piece of tape to cover the hole... make sure nothin gets in the intake horn or tubes...
I have not done this, so I dunno if it will work or not.
I seem to have remembered someone else doing this... I'll look...
LMK what you do...
Old Jun 28, 2008 | 12:41 PM
madhat's Avatar
Check this out...
https://www.dieseltruckresource.com/...+heater+delete
Old Jun 28, 2008 | 04:00 PM
rufushusky's Avatar
I got mine from a Cummins parts counter for like 30 bucks.
Old Jun 28, 2008 | 04:40 PM
Blueboy's Avatar
grid heater
As long as your never going to use it again you can gut it.
I had a spare and gutted it. In the winter I put my stock
one back in. Tape wires separate, then together. zip tie
out of the way.
Old Jun 28, 2008 | 10:33 PM
wow those really helped thanks
Old Jun 28, 2008 | 11:05 PM
06RAM2500's Avatar
DISCLAIMER!!!
LMK what you do...
Only time codes come up is if you unhook the two small wires or the cable coming off of the battery going to the solenoid. All's you need to do is unhook the cable coming off the relay that goes to the grids.
Old Jun 29, 2008 | 08:26 AM
madhat's Avatar
You're welcome! That's what the DTR's for...
Thanks to everyone that chipped in. Can't do it by myself...
Old Jun 29, 2008 | 03:12 PM
hemi_on's Avatar
Why
Question why would you want to get rid of the grid heater any ways
Hemi_on
Old Jun 29, 2008 | 03:38 PM
erf2006's Avatar
how much hp/torque be made by deleting it?
Old Jun 29, 2008 | 04:03 PM
madhat's Avatar
You would want to get rid of it because it is a little restrictive.
The gain is in one of the threads that I attached above.
