fueling up with FASS, while idiling
This might be a silly question to ask. I noticed that in the FASS owners manual that it states not to fill up, with the truck still running. Is this something you MUST not do. Or will it hurt anything if it has been done a couple of times before I noticied that I shouldn't.
thanks
thanks
On some (or most, I don't know) models, the return from the pump is plumbed into the filler line. So when you're filling up, the air coming out of the return line can cause fuel to spray out, or just stop the nozzle from filling. If you can fill it without any issues like this, I wouldn't worry about it.
Its actually was installed in the fill neck vent tube. This is the one you can not fill with the FASS running.
We now install it into the fill neck and you can idel the truck when filling with this set up.
CoolumConst
19
Oct 5, 2008 02:41 PM
ptgarcia
Feb 23, 2007 04:48 PM
fanofthewolf
Apr 19, 2003 06:30 AM
