Fuel Pressure Variation
Old Oct 28, 2004 | 04:25 AM
Barry Smith's Avatar
Hey guys, I just installed my FP gauge last night (Auto-meter Ultra Lite 0-30 psi electric) At idle it's 14-15psi normal driving 13-14, WOT 6-7 psi for 6 or 7 miles like clock work then push in the clutch to turn in drops to 5 psi I take off easing it along drops to 3 psi. I shut it off started it back up and back to 14-15 psi. I was wondering if I could have hooked the gauge up wrong or what the deal was?
Old Oct 28, 2004 | 05:41 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Are the wires all tied up out of the way of moving parts?
Also double check your ground connection.
Old Oct 28, 2004 | 05:44 AM
I was kinda wondering about the ground. I'll check and make sure everything is tied up.
Old Oct 28, 2004 | 06:24 AM
Tazman's Avatar
If you're all wired up right (personally I prefer mechanical) LP is headin' south.
m2cw
Old Oct 28, 2004 | 09:24 AM
Geico266's Avatar
My bet is the pump is going south. I installled my FP gauge yesterday only to find the pump was fluctuating just like you described. Replace the pump to be sure, if it doesn't work you'll have a spare for when it does quit. lol
Old Oct 28, 2004 | 11:12 AM
Thank you! That's very reassuring!
Old Oct 29, 2004 | 02:42 AM
Now when first starting the pressure is 15 then drops to 5 and from there it drops to 0 pretty quik. I guess I'll be replacing a lift pump tommorrow
Old Nov 1, 2004 | 12:29 AM
Well I replaced the lift pump Friday. Boy was that fun. I wish they could put that somewhere that would be hard to get to Now my readings are 15 at idle 13-15 running down the road and 8-9 at WOT. As usual Friday as I was driving around trying to find a pump it read right on the money?
Old Nov 1, 2004 | 08:24 AM
Geico266's Avatar
Did you remove the fuel filter canister? Not too bad of a job the second time! LOL
Old Nov 1, 2004 | 09:17 AM
Geico, dummy me didn't even think about taking off the fuel canister
Haynsling
Apr 18, 2012 07:36 PM
dodgeguy71
17
Jan 19, 2012 12:52 AM
widlin1
Mar 9, 2006 06:17 AM
Vontin111
16
Dec 11, 2005 04:36 PM
PIRO 710
Nov 20, 2004 05:18 PM
