Fuel Pressure Help
It's time for a new LP and I'm not sure what to do. I can only afford to spend around $150 so the FASS is out of the question. I thought about just replacing it with another stock LP and taking my chances and seeing if it will last me a couple more years becuase I don't know if I will even own the truck then. I also thought about buying a pusher pump from EEP but I have heard mixed things. First I hear it works and fixes it then I hear it works for a while but if your LP is bad now you need a new one of those too so we're looking at $300 or more and then I would get the FASS. Now my LP isnt completely shot but its close. Here are my readings:
Idle: 9psi
Cruising: 6psi
WOT: 2psi
So yeah it's pretty much shot. So for the money what should I do? Also wasn't there somplace online that had stock LP's fairly cheap? I like the idea of a push pump but don't like the idea of having to do that AND a stock LP and plus I was reading and it can be kind of tricky to install. I'm open to all ideas, providing that I can afford it! Now I know you have all read a thousand posts like this but I just wanted some specific suggestions for my situation. Sorry for the repeated and dragged on topic. Thanks guys
Idle: 9psi
Cruising: 6psi
WOT: 2psi
You can get a stock lift pump for $150 to $175. For your situation I would go with the stock set up. I use it with a fuel pressure gauge and it will last for a good while. I believe that cummins offers a one year warrenty on thiers.
Originally posted by Cumminsdude
In the tech facts it says the correct Cummins part number for my truck is 3390082. Wont a cummins pump part # 3390105 work also?
dodgeguy71
17
Jan 19, 2012 12:52 AM
MoparRiggan
Jan 5, 2006 11:09 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
