Fuel Pressure Gauge in - Reads 9psi at idle?
I put in a mecanical Isspro in the cab. No leaks & if it ever does it will only be a drip which I can shut off with the needle valve. My pressures are 15lbs at idle, 13lbs at cruise & havn't been able to pull it down below 10lbs wot with 12,000lb 5vr behind
Thanks Rod at Wild Cat Diesel
same here... sent me both.. and a return label... very cool! And he had said he had never heard of a gauge being bad...... well he has now.. Mine was... just my luck to be the first... If it wasnt for bad luck I wouldnt have any luck at all...
Do you recall what the warranty is on these gauges? 7 years was it not?
03qclb5spd
04-03-2007 11:42 PM
getblown5.9
14
04-03-2007 09:23 PM
Buckshotmckee
06-10-2005 12:23 PM
JCHMOTOR
15
06-22-2004 08:25 PM
