fuel pressure gauge
Old Oct 12, 2008 | 03:03 PM
olddodgetrucks's Avatar
fuel pressure gauge
where do i tap into fuel line to put on gauge
Old Oct 12, 2008 | 05:48 PM
Pork's Avatar
you can tap into the schrader valve on the VP, or on some of the earlier 24v's there is a port on the fuel filter housing. mine is at the VP.
Old Oct 12, 2008 | 06:15 PM
its 1999 forgot to put year in
Old Oct 12, 2008 | 08:12 PM
TallTom's Avatar
I have a 98.5 and I believe they are the same. You have two options you can choose pre filter or post filter. I removed the fitting on the top of the fuel filter housing that was closest to the engine and that gives me fuel pressure after the filter. This will allow you to monitor how dirty your filter is getting. Its also handy in the extreme cold to see if your fuel is gelling up. IF the pressure starts dropping add more power service.
TallTom
Old Oct 14, 2008 | 02:16 PM
6cylinders's Avatar
I went with high flow banjo bolts, I got 2 that were drilled and tapped, shrader valve in one and fuel pressure guage
in the other, post filter. Here is a link to a pic, I didn't get them from here but many companys sell them.
http://www.citydiesel.net/banjo-bolt...ins-p-210.html
Old Oct 14, 2008 | 02:23 PM
6cylinders's Avatar
Geno's sells just a single one and they are great to deal with.
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
