Could this cause this
Old Oct 14, 2008 | 05:21 PM
cowboy2526's Avatar
Could my batteries being corroded and the positive cable conector on the drivers side is broke in half and held together with a penny.
My question is could this cause these codes to come up.
codes: 0122,1693,0252,0216
Old Oct 14, 2008 | 06:21 PM
badme's Avatar
Probably not, but it would be a good and cheap start to fix it and reset the codes and see if they come back.
Old Oct 14, 2008 | 06:37 PM
cowboy2526's Avatar
ok that is what i will do, do you know of a way to get the corrosion off the batteries.
Old Oct 14, 2008 | 07:24 PM
sheriffav8r's Avatar
Warm water and baking soda with a toothbrush does a pretty good job....
Old Oct 14, 2008 | 07:37 PM
badme's Avatar
do like sherrif said.
Old Oct 14, 2008 | 07:38 PM
cowboy2526's Avatar
Thank you guys for your help. Can i just use some replacement ends or do i have to buy oem style cables.
Old Oct 14, 2008 | 07:41 PM
badme's Avatar
Lot of people use the replacement ends. They work but are considered a band-aid. I would use oem type on my truck, I hate walking.
Old Oct 14, 2008 | 08:03 PM
P.J's Avatar
P.J
Those codes are not very promising. What kind of fuel pressure are you seeing?
Please tell me you have gauges if you are running that Smarty in your sig.
Old Oct 14, 2008 | 08:53 PM
cowboy2526's Avatar
no that smarty is off my 07 that got totalled. and no i dont have gauges this is a recent purchase (01) and has not ran since i bought it.
Old Oct 14, 2008 | 11:08 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Ok first off you need too get a gauge on the truck too see what you are running as far as fuel pressures go. But seeing the 216 code is not a good sign usually a death code fro your injector pump but not always. Here is a few shots of how I set my 01 up for my fuel gauge. Don't bother with a isolator they will give you headaches after headache just run the line too the cab and cover any spots that might rub with wire loom sheaths. The reason I mounted mine low was I figured if there was ever a leak it would fill up the floor mat vs filling my whole dash full of fuel.
This is were I put my line on its the test port on the vp-44/injection pump
Second my gauge is mounted right directly in front of the 4x4 shifter out of sight and out of mind.
Old Oct 14, 2008 | 11:10 PM
cowboy2526's Avatar
That is an awesome post are those fittings something I can pick up at a parts store or something I have to order.
Old Oct 14, 2008 | 11:14 PM
DTR's Cow Boss
Tell Eric or who ever you deal with there that would would like solid mount end not the swivel end on the hose. 6ft of hose will reach beautiful too were I have mine mounted.
http://www.vulcanperformance.com/ser...w-fdsh-/Detail
Old Oct 14, 2008 | 11:17 PM
cowboy2526's Avatar
Did you have to drill a hole through the firewall.
meanfarmer
Oct 2, 2006 09:10 PM
Mexstan
39
Aug 19, 2005 12:53 AM
Clint
Nov 28, 2004 04:04 PM
Mark Thomas
Oct 28, 2004 06:05 PM
