fuel pressure arithmetics
Old Aug 9, 2005 | 08:49 PM
george7941's Avatar
I was getting 8psi fuel pressure at idle with the stock lift pump and also 8 psi with a holley blue installed as a pusher with the stock pump bypassed. However when I install the two pumps in tandem (series) I am getting 25 psi at idle and am also getting hard starts. How does 8psi + 8psi = 25psi. I expected 16psi. What is going on?
Old Aug 9, 2005 | 08:53 PM
george7941's Avatar
oops! I forgot that my fuel pressure gauge underreads and so the pressures are actually 10, 10 and 28psi.
Old Aug 9, 2005 | 08:58 PM
Shovelhead's Avatar
Administrator / Scooter Bum
10 + 10 = 28
Must be the same math that the oil companies are using to set the price at the pump.
Old Aug 10, 2005 | 09:21 AM
HOHN's Avatar
LOL@ Ed.
It's simply efficiency. Just like when you talk about twin turbos. One turbo @25psi feeding another @25psi should give 50psi total, right? Nope-- closer to 70+.
Your hard starting is a result of the high fuel pressure. Keep it under 18 or so and hard starts will go away.
jlh
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
