Auto Trans Wont Shift
Old Aug 8, 2005 | 02:28 PM
yz450f's Avatar
My 01 4x4 when i am on the edge on level 3 or higher when you get on it from a stop or little roll the trans will no shift out of 1st untill you let up but if you ease into in on level 5 it will shift is this a sign that my trans is going. if so where in the detroit mi area is a good place to get it fixed and what up grades can i do. truck has 160,000 miles and has allways had tranny oil changed. never have had the trans serviced besides oil change. thanks
Old Aug 9, 2005 | 06:17 AM
yz450f's Avatar
anyone have this problem before or does anyone know of a good place to take it to be fixes or what new goodies to put in it thanks
Old Aug 9, 2005 | 08:33 AM
Mike D's Avatar
Could be something as simple as a TV cable adjustment.
Old Aug 10, 2005 | 10:11 AM
RowJ's Avatar
You mention changing Tranny Fluid...did you change the fliter also...or adjust the bands? If not I would start there.
Dodges have had reported problems with not going into 1st gear...starting out in second. Mine did this and it was "pressure accumulator switch"...or something like that. It was an fairly inexpensive fix at the dealer. Sound somewhat similar to your problem.
Don't know anyone in Michigan...but I would call DTT...see if they have an installer in your area. He can diagnose your problem and you can go from there. They are experts on our trannies and don't just do the full DTT rebuilds....at least until you need it!
Nice people to deal with... http://www.dieseltrans.com/
RJ
Alwaysbroken530
Aug 17, 2013 09:31 PM
rustydeeretech
Jun 16, 2010 09:41 AM
kingofdodge7131
0
May 18, 2007 06:20 PM
xcomandos
Oct 28, 2006 09:28 AM
97catintenn
Aug 24, 2005 06:01 PM
